bearing axle shaft retainer leak
I have a leak from the axle shaft retainer plate, that bolts onto the transaxle. Does the whole back side of the retainer need to be covered by a light coat of sealer?
There's a 1/2" x 1/4" hole at the bottom of the transmission that gets covered by the retainer. The last person didn't cover the whole back side with sealer ( around that bottom hole was not sealed ) I was wondering if that is why it was dripping. The axle seal is not leaking by the way. Also what the torque spec. it's not listed in repair manual?
Thanks!
Thanks!
