Radio- no sound
Old Dec 10, 2005 | 03:36 PM
HotSauce's Avatar
HotSauce
Default Radio- no sound
I have an aftermarket radio in a gen 2 neon. It works, cd goes in and out, radio runs fine, but No sound is coming out. YES the radio did work before, untill recently. I checked the fuses but not sure where to go from here.
ANYHELP??
THANKS!
H.S.
Old Dec 10, 2005 | 03:38 PM
casper's Avatar
casper
Default RE: Radio- no sound
Have you changed anything since it was working? If it was working and now isn't I would say you blew it. There usually is a fuse on the back of the radio or the power wire, but usually not a separte one for just the amp.
Old Dec 10, 2005 | 03:41 PM
HotSauce's Avatar
HotSauce
The radio works, fuses look good. BUT, no sound now, sound did come out Before. The unit works as fas as the display, but JUST no sound. IDK maybe some wiring or something, but no sound is coming out of all the speakers.
Nothing else as far as aftermarket, but would the factory amp cause this?
Old Dec 10, 2005 | 03:49 PM
casper's Avatar
casper
What factory amp??
Did you have the radio in the car and working?
If you are just putting it in now you probally wired it wrong double check
Old Dec 10, 2005 | 03:53 PM
HotSauce's Avatar
HotSauce
Yeah, i didn't know if there was a factory amp. Ok here is the deal. It worked previously, sounds & display. NOW it has no sound. Did NO changes after it was put in, to the time it quit and stopped putting out sound.
I guess I can just check the wires in the back and make sure one didn't come loose.
Other than that I don't know.
Old Dec 10, 2005 | 03:58 PM
casper's Avatar
casper
If its wired right it should work. On some radios the amp is powered from the constant 12V yellow wire and the display and such are from the red Acc wire. Do your presets stay when you turn the key off? Take a meter and check to see that you have power to the radio. Other than that if its wired right and you have power to all the wires to the radio I'd say you blew the amp or all you speakers went at once.
Old Dec 11, 2005 | 01:00 AM
HotSauce's Avatar
HotSauce
Thanks, I'll find out in a few days when I get home.
Old Dec 11, 2005 | 01:29 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
I dont know if any generation Neon got the Infinity sound setup, but I do know that typically when all the speakers quit working at once....it's usually one of three things....the head unit...the fuses....or the pre-amp.
Since you already eliminated the fuses.....then that only leaves two things..
If you are getting power to the head unit, then I would start by checking the pre-amp. Typically, these are located in the passenger side kickpanel. Also, taking a power meter like Casper suggested and applying it to the pre-amp and the radio is a great idea.
If you can't figure it out, it's probably best to have a professional look at it.
Good luck!!! Hope this helps
Old Dec 11, 2005 | 01:44 AM
casper's Avatar
casper
No there is just a regular raido and speakers in a stock neon.
