Correct way to balance tires? steering wheel shake still???
Ok, did the 4 wheel alignment and redid the 4 wheel (regular-free) balance. They could not find anything loss on the front end. The newer tires all look good no broken belts etc. They said the rear rim and spare both have a small (hop) bent inside of rims. Told me to keep that tire in back when rotating tires. Still have a car shake at 50 to 55mph. Any thoughts of what to try next, just checking before I move on?
Ok good feedback. Where is the 50-55 "shake", front, back, passenger or drivers side??? If you feel the shake in the seat, its likely in the rear, if its in the steering wheel, its likely in the front wheels.
Did you get the new tie rod ends installed, alignment check, the bent wheel swapped out & resolved the wheel bearing question you posted about?
How would I check for a bad bearing? People have said all my problems could be caused by a bad wheel bearing. All the wheels are tight, while grabbing them at 12, 6 o clock- 9,3 o clock. I tried to spin them but the brakes are dragging a little so I can't hear anything.
When the vehicle is rolling on a smooth surface, shift to " N" & listen for a rough cyclic sound. Try to determine if its from the front or rear & which side.
Then go to the suspect wheel, raise it off the ground & push the calipers back to free up the wheel & spin the wheel & listen for the same type sound.
Check for bearing play, or readjust the bearing play to spec & retorque the retainer nut to spec & go for another drive to determine if the sound changed.
Unless the bearing is really loose, or worn out & causing the wheel to wobble, its not likely the root cause of your vibration problem as has been suggested in this thread.
For now I'd stay focused on the wheels & concentrate on getting 4 known good & balanced wheels & tires on the ground & see how it goes over the same stretch of smooth road.
If the vibrations continue, I agree, move One of the rear tires to the front on the side the vibrations seem strongest & see if the vibes stop or get better in the front, & or move to the rear, then put that tire wheel combo higher up on your suspect list.
If the front still vibrates, do the same front to rear swap on the other side & see if the vibrations improve, or stop in front. Do the drive test over the same stretch of smooth road at the same speed.
Make sure to take the guys at the tire shop for a drive, so they can see, hear & feel the vibrations your concerned about.
More thoughts for consideration, let us know what you find.
