Is there a bearing inside the trans for the front axle?
Old Aug 10, 2019 | 08:38 PM
mike L's Avatar
mike L
Default Is there a bearing inside the trans for the front axle?
Is there a bearing inside the trans for the front axle, pass. side? Good year said I have a bad bearing inside the trans. also a bad pass. axle. Is it part number A35? also how do you get the bearing out once you remove the housing with the four bolts?
Old Aug 12, 2019 | 12:30 PM
ol' grouch's Avatar
ol' grouch
You have a bearing/hub assembly on the steering knuckle. It's not in the transmission. As for part #, I have no idea. To remove the wheel bearing, you'll need to remove the caliper and bracket to get the rotor off. Remove the center nut from the axle, remove the bolts and pull it out. If the axle is bad, that's when you replace it too. Don't pull anything out of or off the transmission. The drive axle should pop right out. Don't mess with the transaxle unless you want to rebuild it.
