p0122 p2074
Old Aug 13, 2019 | 02:10 PM
Slimjim71884's Avatar
Slimjim71884
Default p0122 p2074
Alright guys so i had the 2 codes above pop. replaced both the tps and the map sensor, then found vacuum leak in brake booster via smoke machine, replaced it as well. im still having the same problems. Idle goes up and down between about 900 and 2000 rpms. sometimes it runs fine and other times it spits and sputters really hard and wont accelerate, some times while driving it will bog down and not allow rmps go over 2500ish. ive checked all lines for vacuum leaks but cannot find any other than the brake booster. any ideas? thanks
Old Aug 28, 2019 | 12:01 AM
paw paw's Avatar
paw paw
Are these the same problems you were having here ??? https://dodgeforum.com/forum/2nd-gen...ml#post3400512
Old Aug 28, 2019 | 06:02 PM
Slimjim71884
Yea it went away and cane back thats when i found the brake booster was leaking. Replaced the booster a week ago traced wires making sure no split anywhere or bad ground. Problem continued for about 24 hours and now it is running pretty good. Still has a hesitation in spots sometimes so i may still have a vacuum leak somewhere or tps and computer didn't quite synchronize up properly.
