CAN FOG LIGHTS WORK WITH MARKER LIGHTS ON ???
Old Dec 14, 2005 | 11:35 PM
tyson724's Avatar
tyson724
Default CAN FOG LIGHTS WORK WITH MARKER LIGHTS ON ???
I HAVE A 2000 DODGE NEON ES . I JUST WANTED TO KNOW IF IT WAS POSSIBLE TO HAVE THE FOG LIGHTS ON WHEN THE MARKER LIGHTS ARE ON ? CAN IT BE DONE AND HOW ????
Old Dec 15, 2005 | 01:55 PM
scaredpoet's Avatar
scaredpoet
Default RE: CAN FOG LIGHTS WORK WITH MARKER LIGHTS ON ???
Doesn't look like it can, at least not with the stock signal stalk. That pull-out switch used for fog lamps retracts and turns the lamps off when you turn the switch to parking lights or off.
Old Dec 15, 2005 | 02:29 PM
tyson724's Avatar
tyson724
is there a way to wire or rewire fogs to come on with markers ?
Old Dec 16, 2005 | 02:45 AM
casper's Avatar
casper
Use an aftermarket switch and wire them into the parking lights is the easiest
