Valve compressors
Old Dec 19, 2005 | 05:02 AM
lblackneon's Avatar
lblackneon
Default Valve compressors
Does anyone know if any businesses (like Discount Auto Parts) rent out valve compressors? The reason I'm asking is b/c I'm thinking about doing the cam job w/ valve springs etc.
Old Dec 19, 2005 | 07:37 AM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: Valve compressors
autozone probably does...
Old Dec 19, 2005 | 03:41 PM
casper's Avatar
casper
Yes they do. And its free too.
ORIGINAL: highrevr/tflea
Old Dec 19, 2005 | 10:49 PM
lblackneon's Avatar
lblackneon
Nevermind; I need an air compressor. The mechanic I'm talking to said he already has a valve compressor. He said having an air compressor with the valve compressor makes the job easier. Autozone does have valve compressors for rent for about 20 dollars. I just got through checking today.
That being said, are there any air compressors for rent out there?
Thanks.
Old Jan 20, 2011 | 09:54 AM
silentdub's Avatar
silentdub
yeah, that is a different tool, you can pump the cylinder up with air so that you can swap the springs without removing the head.
Old Jan 20, 2011 | 12:18 PM
hemi4spd's Avatar
hemi4spd
you pump the cylinder with air so when you remove the retainer and spring the valve doesnt fall into the engine
heres a tip put affected cylinder to TDC before removing the valve then when it drops a little the piston will keep it from falling down inside the cylinder
