Crank sensor reset?
Old Jun 26, 2023 | 06:55 PM
Gunk's Avatar
Gunk
Default Crank sensor reset?
Hello,
I could use some guidance. I recently replaced the water pump and timing belt on my 03 SE Neon. At first it didnt want to start. Later, it finally did and I drove it a mile and it seemed to run fine. Now, it starts first try.
However, I have a flashing engine light. These are my codes:
Ive read about a crank sensor needing to be reset with a fancy scanner in some situations.
My question is if that is a normal procedure to do when changing a timing belt?
Is it possible this P0315 code saying crank variation not learned is because the sensor needs to be reset?
Or is it more likely that I installed the belt with the timing off?
Any input is greatly appreciated.
