Coil packs
Old Jun 26, 2023 | 09:56 PM
Nacho715's Avatar
Nacho715
Default Coil packs
I’ve on my 2nd msd coil pack both brand new in box and it throws my car into limp mode are msd coils just bad coils it’s on a 2003 dodge neon r/t just lookin for so advise
Old Aug 21, 2023 | 10:40 PM
paw paw's Avatar
paw paw
I see no replies & you've likely found the problem by now but I'll see if I can get things started. Use your scan-tool, code reader, or parts store to scan for codes, or cycle the ignition switch from Off to On (but don't crank the engine), 3 times, stopping at On the third time & view the dash info or mileage display while the vehicle ECM puts up any trouble code clues. Post All code Numbers, as they can help focus a trouble-shoot.
If your still in doubt about the coil packs, most autoparts stores can & will bench test them at no cost.
Some beginning thoughts for consideration, let us know what you find, or have since found.
Old Aug 29, 2023 | 09:34 AM
Nacho715's Avatar
Nacho715
Default Yes and no
I used my old coil pack and the codes went away so really I don’t know but codes from the code reader pretty much pushed me back to they were bad
Old Aug 29, 2023 | 09:57 AM
paw paw's Avatar
paw paw
Ok good feedback on reinstalling the OEM coil-pack & having the codes take a hike. I don't follow MSD product history, but having worked in the electronic industry 37 years, MSD doesn't likely make their own coil-packs & if contracted for & made overseas, one has to wonder to what QA specification, so there is that variable. It's possible if those two coils were made at the same time, the factory may have had a process, or material problem that QA missed. All speculation on my part.
