jerking problem
Old Feb 17, 2006 | 01:09 AM
dirtrider222's Avatar
dirtrider222
Default RE: jerking problem
i read a code today on it, it was misfire cylinder 2, i had a injector layin around so i changed it out and notices no difference. i had previously changed the coil plugs and wires, but still dose the sam thing. its backk fireing into the intake and has almost no power when starting off in first gear. it seems to only so this under load at low rpm (below 3,00rpm) anyone know what this could be?
thanks again
joe
Old Feb 23, 2006 | 01:59 AM
TJW815's Avatar
TJW815
I have the same problem and people keep telling me to look for lose vacuum lines, I have no idea what I'm looking for. can someone elpain this to me
Old Feb 25, 2006 | 02:07 AM
TJW815's Avatar
TJW815
I think i figured it out on mine, there is a van line (looks like the pcv line) that runs from the throttle body to the back of the valve cover, mine had, well, fallen off, that caused mine to do the same thing. now its fixed, I already ordered my msd coil and super conductor cables to attempt to fix it, but puttin them on anyways, they could only make things better.
