coil pack
Old Jan 16, 2006 | 09:03 PM
dirtrider222's Avatar
dirtrider222
Default coil pack
is changing the coil pack on the 2nd gen neons prevcentive matainance such as doin the plugs and wires or dose it not need to be changed often?
Old Jan 20, 2006 | 03:19 PM
lblackneon's Avatar
lblackneon
Default RE: coil pack
You normally don't need to change them until they break and aren't running as they should. The coil is on the top of the engine so it couldn't be any easier to get to. If it was burried in the engine and very hard to reach and I was changing something around it, then I'd probably change it if it would save me labor.
Old Jan 23, 2006 | 05:40 AM
orion96325's Avatar
orion96325
one way to tell if the coil is on it's way out is if you are experiencing a miss with load on the engine. you may even get a backfire through the intake, but just make sure you don't have a bad timing belt or faulty valves. i just replaced my coil with a MSD unit and it functions perfect. i thought at first there was a timing issue, but these stock coils just are not made for 7000rpm playing. use good wires like Accel or MSD with low impedance for best performance.
