Problem Solved
First of all I want to say thank you for those of you who replied to my post about the reverse problems and the vibrating to where I thought it would quit.
Turns out I had 2 broken motor mounts, a very bad leak in my water pump and an oil leak. Got the 2 motor mounts fixed and the water pump replaced. They also replaced the timing belt. It has 105,000 miles on it. Anyways.. when I am stopped at a red light or stop sign or wherever.. my car has a really bad vibrating noise like it's going to die then it hurries up and goes back to normal.. any clue on what that might be? |
RE: Problem Solved
Could be the idle air controller on the throttle body. When your engine is at idle , the throttle is closed and the engine pulls air through the IAC to keep at idle
RE: Problem Solved
ORIGINAL: csmsach Could be the idle air controller on the throttle body. When your engine is at idle , the throttle is closed and the engine pulls air through the IAC to keep at idle |
