E-Brake Question...
ok i read up on it theres no way 2 tighten the brakes with a bolt cuz they r self adjusting which means u have 2 back up and stop a lot of simes to tighten them i think or at least thatz the impression i got from what i read i no self adjusting brakes arent the best thing in the world and dont really work all of the time so ne other ideas would b good 2
So how am i *drifting*(lol) around corners if the rear wheels dont lock up when i pull the e-brake? I thought that was the whole point of an e-brake, to lock the back tires when you need them in an E-mergency??
no the e-brake is there so if u have a manual then ur car wont roll away and also to help stop in an emergency but its not meant to stop the car and u can drift around turns in a neon without pullin the e-brake cuz its so light i do it all the time
mmmm...*pulls e-brake on lightly snow covered road around corner*
haha anyways yeah it makes your tail come around more when you pull the e-brake...at least thats my perspective.
ORIGINAL: 03neonRT
You know i must not have been thinking this through very well b/c i have 4 wheel disc abs...and what does abs stand for eveyone, yes Anti-Lock Braking System...now everyone give me a round of applause for being the dumbest SOB tonight!
haha things seem so much simpler when Casper joins a topic...
ORIGINAL: 03neonRT
If you want to tighten the brake tighter than the auto adjusting mechanism does, there is a way to manually adjust them. Behind the inside cover for the drim brakes, on the top side, there is a rubber peice that is somewhat of a rectangle. Pull out that piece, and there is a hole, which is for you access the adjusting mechanism. There are teeth on it so that you can turn it with a flat head screwdriver. Just poke a screwdriver in the hole, and use it to turn the adjusting screw upward. keep doing it till you cant anymore.
