rims size?
Old Feb 1, 2006 | 07:09 PM
spikeymikey87's Avatar
spikeymikey87
Default rims size?
i wanna gat 17s but should i get 17x7 , 17x7.5 , or 17x8 and wound i run the risk of rubbing i got a stock suspension on a 04 sxt
Old Feb 1, 2006 | 07:17 PM
twk62390's Avatar
twk62390
Default RE: rims size?
17X7 any thing larger will rub. But my 17X7 s rubded both front and back at first but were ok after i got spacers.
Old Feb 1, 2006 | 07:18 PM
03neonRT's Avatar
03neonRT
17x8 will rub in the back and you will need to get spacers, i'm not sure about 17x7.5, and 17x7 should fit perfectly.
04ryanR/T's Avatar
04ryanR/T
well i know that MP sells spacers for rims if that helps at all...dont know if that would be enough to solve any suspension problems that too wide of tires would cause?? im currently looking at 17x7.5
Old Feb 2, 2006 | 01:08 AM
LowSlowNeon's Avatar
LowSlowNeon
I think it depends on the offset of the rim as to whether it will rub or not. I got 17x7s on my car and I don't believe its even close to rubbing.
