thermostats
Old Feb 2, 2006 | 07:22 PM
04ryanR/T's Avatar
04ryanR/T
Default thermostats
this is probably a stupid question but then again how do you learn...
i know that a higher temp thermostat will make the engine run cooler...but is there any downsides or worries with this application
if theres a site that i missed that explains this just post a link...thanks
Old Feb 3, 2006 | 02:03 PM
tooslow's Avatar
tooslow
Default RE: thermostats
lower temp thermostat should make your car run cooler. The only thing it is going too change is often your radaiter fan comes on.
Old Feb 3, 2006 | 03:09 PM
whyte69's Avatar
whyte69
Going to a cooler thermostat makes the engine's computer think that it's running hotter. The thermostat is what reminds the engine that it needs to cool itself. There is a range of temperatures that your engine will run most efficiently. Running too cool and you risk losing some of that efficiency. A 160 degree thermostat isn't all that suitable for colder climates, but a 180 degree thermostat will serve you just fine.
