2002 neon computer location
Old Feb 18, 2006 | 08:11 PM
randallgroves's Avatar
randallgroves
Default 2002 neon computer location
Can anyone tell me where the computer is located on my 2002 neon 4d? I've looked all over and can't find it. I'm trying to figure out if the rough low speed idle computer re-flash has been accomplished. The TSB says that if it has been done, there will be a sticker on it.
Thanks
Old Feb 18, 2006 | 08:12 PM
randallgroves
Default timing belt - 2002 neon
When should the timing belt be replaced? One place says 100K, and another says 60K. How much should it cost?
Thanks
Old Feb 18, 2006 | 08:48 PM
lblackneon's Avatar
lblackneon
Default RE: timing belt - 2002 neon
The timing belt should be replaced around 90-100 thousand miles. When u do that you should also change the water pump and the thermostat and u might as well change your other belts.
Neons computer is located at the way front of the car in the engine compartment basically around the bumper. U should see a few thick plugs running to it next to the fan area.
Old Feb 20, 2006 | 11:57 AM
Neonsxt's Avatar
Neonsxt
take ur airbox off and you will be able to see it very easily...
Old Feb 21, 2006 | 12:27 PM
04 mo neon's Avatar
04 mo neon
What was dodge thinking by putting the MAIN CPU right by the frount bumber where the most impact would likely be in a crash. WTF
Old Feb 21, 2006 | 01:18 PM
lblackneon's Avatar
lblackneon
Hmm; I never thought of that. Everything on the car is easy access though.
Old Nov 2, 2012 | 01:59 PM
illriginalized's Avatar
illriginalized
roflmao..
My infiniti's ECU is inside the cabin, at the bottom of the center dash by the gas pedal.
Dodge, you so funny, brah. Guess you want to make your customers miserable in front end car accidents.
