speedo cluster ?
Old Feb 18, 2006 | 09:38 PM
ryanmills06's Avatar
ryanmills06
Default speedo cluster ?
Does anybody know if a 03-05 speedometer cluster will work in a 2000?
Old Feb 19, 2006 | 01:00 AM
nicks2kes's Avatar
nicks2kes
Default RE: speedo cluster ?
i think they will not positve though, why would u want to switch them anyways they are the same unless u are gettin srt-4 ones
Old Feb 19, 2006 | 07:42 AM
whyte69's Avatar
whyte69
they should work, there's no reason why they shouldn't work. The only difference would be if you had put an SRT-4 gauge cluster into a Neon. The SRT-4 cluster would read differently due to different markings on it. You might try asking lblackneon he recently did the SRT-4 cluster swap and I was a bit interested to hear how that went.
Old Feb 19, 2006 | 11:10 AM
LowSlowNeon's Avatar
LowSlowNeon
Actually that was me and the readings are the same. No problems other then it shows whatever mileage is on the cluster.
Old Feb 19, 2006 | 03:53 PM
ryanmills06
The only reason i am switching out the cluster is because I dont have the tachometer in my cluster now, I have a autometer tach, but i like the look of the white face gauges and definitely would like an in-dash tach
Old Feb 23, 2006 | 01:40 AM
TJW815's Avatar
TJW815
it will swap and work with no problems aside from the odometer being wrong. Try to buy one that has a few more miles than yours and change it when it is really close, thats what I ended up doing
