AMP Help
Old Mar 17, 2006 | 05:48 PM
senoner's Avatar
senoner
Default AMP Help
i installed an amp and two subs on my 2005 dodge neon, but the REM Led light on the amp doesnt light up, is the amp not getting power?
Old Mar 17, 2006 | 08:48 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: AMP Help
check ur power supply and also is the rem is gettin 12 volts its just a on/off switch but it still needs constant power flow i can try running it to the fuse for your radio so that the amp will alwayz be on when the radio has power
Old Mar 28, 2006 | 03:02 AM
DarkNeoSXT04's Avatar
DarkNeoSXT04
definetly check ur ground....if ur ground isnt good ur amp wont turn on no matter how much power ur giving it.....try that and see what happens
Old Mar 28, 2006 | 03:05 AM
casper's Avatar
casper
Remove your remote wire from the amp and then connect a small wire from the positive cable to the remote connection on the amp. If the amp powers up your remote wire is not getting power to the remote wire. If it does not turn on there is something wrong with your amp.
