Steering Whining Noise
Old Mar 17, 2006 | 07:11 PM
UKNeonRT's Avatar
UKNeonRT
Default Steering Whining Noise
Hi everyone, I have a 2001 Neon RT. Basically, when I turn the steering either fully to the left or right (i.e full lock) and move forward, there is a loud whining/groaning noise. As soon as i move off of full lock - even just a little bit, the noise goes away. Is this normal? And any ideas what it is please :-)
Many Thanks
Old Mar 17, 2006 | 08:50 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: Steering Whining Noise
thats your steering box screaming for help its normal just try not to turn your wheel all the way left or right
Old Mar 18, 2006 | 02:35 AM
whyte69's Avatar
whyte69
agreed. You shouldn't be turning your steering wheel all the way in either direction. If you need to be turning that much, turn it all the way and then back off about an inch or two and it should stop screaming at you.
Old Mar 18, 2006 | 05:32 PM
UKNeonRT's Avatar
UKNeonRT
Thanks guys. Just wanted to check that i didn't need to get it checked out! :-)
Old Mar 28, 2006 | 03:01 AM
DarkNeoSXT04's Avatar
DarkNeoSXT04
this might seem like a dumb question but have u checked ur power steering fluid....low fluid could also cause a whining noise....heard it many times at the shop
Old Mar 28, 2006 | 03:02 AM
casper's Avatar
casper
Check the power steering fluid level, if its full its normal.
Old Mar 31, 2006 | 06:27 PM
UKNeonRT's Avatar
UKNeonRT
Hello, Its full, so I guess normal. Its fine unless I turn it full lock - which I haven't done since :-)
Old Apr 2, 2006 | 03:55 AM
ewetho's Avatar
ewetho
The reason fo the extra noise is when you go full left or right the system goes to max pressure and dead heads (No Flow) and should not maintain this position for more than 10 seconds and if you back off 1/4 turn or less you will not loose much turning radius. Completely normal on almost all power steering systems. Relative noise to the cabing has many variables from pump design and sound deading material.
