2001 Neon Headlight Replacement
Old Mar 22, 2006 | 09:23 PM
mrloconte's Avatar
mrloconte
Default 2001 Neon Headlight Replacement
Hi guys. My headlight is out, do I need to just replace the bulb or pull the whole thing out? It's on the passenger side so if anyone is familiar with how to do it any help it VERY much appreiciated.
Thanks to all!!!!
Old Mar 22, 2006 | 10:55 PM
whyte69's Avatar
whyte69
Default RE: 2001 Neon Headlight Replacement
it's a bit of a tight fit, but you can just stick your hand behind the headlight and screw the wiring cuff off and pull the bulb. The driver side is tight if you've got the stock airbox in there, but is pretty simple if you've got an aftermarket CAI.
