2003 rear suspension torque specs
Old Apr 5, 2006 | 06:00 PM
2004ram5.7's Avatar
2004ram5.7
Default 2003 rear suspension torque specs
Hey i have a 2003 neon sxt. I was wondering what the rear suspension torque specs are. If anyone could help that would be great.
Old Apr 5, 2006 | 09:57 PM
RadarLove's Avatar
RadarLove
Default RE: 2003 rear suspension torque specs
STRUT ASSEMBLY:
Tower Attaching Nuts 34 N·m (300 in. lbs.)
Knuckle Attaching Bolts 88 N·m (65 ft. lbs.)
Strut Assembly Shaft Nut 75 N·m (55 ft. lbs.)
Brake Hose Bracket
Mounting Bolt
31 N·m (275 in. lbs.)
KNUCKLE:
Brake Support Plate
Mounting Bolts
Disc Brake Adapter
Mounting Bolts
HUB AND BEARING:
To Knuckle Retaining Nut 217 N·m (160 ft. lbs.)
Wheel Mounting Nuts 109-150 N·m (80-110 ft.
lbs.)
LATERAL ARM:
Nut At Crossmember 88 N·m (65 ft. lbs.)
Nut At Knuckle 95 N·m (70 ft. lbs.)
TENSION STRUT:
Rear Nut 95 N·m (70 ft. lbs.)
Frame Rail Bolts 95 N·m (70 ft. lbs.)
Parking Brake Cable Nut 28 N·m (250 in. lbs.)
STABILIZER BAR:
Cushion Retainer Bolts 34 N·m (300 in. lbs.)
Link Bolt Nut 23 N·m (200 in. lbs.)
