cutting out
Old Apr 9, 2006 | 12:49 AM
leadspud's Avatar
leadspud
Default cutting out
Just went auto cosing to day. The last run I made I got my fastest time. But the car is cutting out now. You give it throttle it cuts out at about 2000 RPM's and under a load it is worse.If you give it very light throtle pressure you can sometimes get up to driving speed. Any Ideas. PS when it is cutting out every warning light on the dash are turning on and off
Old Apr 9, 2006 | 03:00 PM
leadspud's Avatar
leadspud
Default RE: cutting out
After running the car a little this morning. It was still doing it. So I took the msd coil off and put the stock coil on. Now it runs great. It was a little damp around the msd coil. If this still works, I will go to a screemin demon coil
