03 neon sxt front torq spec
Old Apr 14, 2006 | 04:53 PM
phatstrat96's Avatar
phatstrat96
Default 03 neon sxt front torq spec
Hey i was wondering what the front suspension torque specs are on a 03 sxt
thanks
Old Apr 14, 2006 | 07:55 PM
RadarLove's Avatar
RadarLove
Default RE: 03 neon sxt front torq spec
STRUT ASSEMBLY:
- Tower Nuts 34 N·m (300 in. lbs.)
- Steering Knuckle Nuts 54 N·m (40 ft. lbs.) + 90° Turn
- Strut Shaft Nut 75 N·m (55 ft. lbs.)
STEERING KNUCKLE:
- Ball Joint Stud Pinch Bolt Nut 95 N·m (70 ft. lbs.)
- Disc Brake Caliper Adapter Mounting Bolts - SRT-4 104 N·m (77 ft. lbs.)
- Disc Brake Caliper Guide Bolts 22 N·m (192 in. lbs.)
- Disc Brake Caliper Guide Bolts - SRT-4 35 N·m (26 ft. lbs.)
WHEEL BEARING AND HUB:
- Bearing Retainer Plate Bolts 28 N·m (250 in. lbs.)
- Driveshaft Hub Nut 244 N·m (180 ft. lbs.)
- Wheel Mounting Nuts 135 N·m (100 ft. lbs.)
STEERING GEAR:
- Crossmember Bolts 68 N·m (50 ft. lbs.)
- Tie Rod Adjusting Jam Nut 75 N·m (55 ft. lbs.)
- Tie Rod End Steering Knuckle Nut 54 N·m (40 ft. lbs.)
LOWER CONTROL ARM:
- Front Pivot Bolt 163 N·m (120 ft. lbs.)
- Rear Pivot Bolt 237 N·m (175 ft. lbs.)
STABILIZER BAR:
- Cushion Retainer Bolts 28 N·m (250 in. lbs.)
- Link Nut 31 N·m (275 in. lbs.)
