When I change my spark plugs...
Old Apr 16, 2006 | 04:44 PM
Mike_02sxt's Avatar
Mike_02sxt
Default When I change my spark plugs...
...should I disconnect the battery?
Old Apr 16, 2006 | 07:47 PM
Topher's Avatar
Topher
Default RE: When I change my spark plugs...
Just make sure you key is out of the ignition, that should be safe enough. You can disconnect the battery if you want to be extra safe but I never do.
Old Apr 17, 2006 | 12:11 AM
casper's Avatar
casper
There is no need to disconnect the battery.
Old Apr 17, 2006 | 01:17 PM
RadarLove's Avatar
RadarLove
The FSM says to disconnect the battery for nearly anything having to do with electricity... including spark plug replacement. It's a bit overkill though. I could see pulling the fuel pump fuse maybe, but I just disconnect the connector at the coilpack.
Old Apr 21, 2006 | 05:55 PM
dakotaquadsport's Avatar
dakotaquadsport
ORIGINAL: RadarLove
Remote start systems. An uncle of mine works for a dealer and once a mechanic was working on a car, replacing a belt, and the car just started cranking over by itself....not pretty....the owner forgot to mention that the system was malfunctioning.
