oil sandwitch plate???
Old Apr 28, 2006 | 08:08 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default oil sandwitch plate???
ok i have a question, i have seen these online, ebay and some othersites, it is for the turbo lines to screw into the return lines, i under stand that i can go the cheep way out and thread the oil pan but i think it will be alot easyier to use this plate??? but my question is it as reliable and does it flow as good??? i think these comes with the hahn turbo kit but not sure, can anyone help me with this any info on this would be greatly apriciated!!!!!!
http://cgi.ebay.com/ebaymotors/OIL-F...QQcmdZViewItem
any help with this would be GREATLY helpfull!!!!
Old Apr 28, 2006 | 09:57 PM
tooslow's Avatar
tooslow
Default RE: oil sandwitch plate???
it would be a good place too run oil feed from but not oil drain. the oil filter is under presure you'l blow the seals on the turbo
Personally I would not use that for oil feed either. Just unscrew the oil presure sensor get yourself a 3/8npt brass tee from your local parts store or home depot. Just be sure too use yellow teflon(oil disolves the white kind) tape on all fittings
