why can you fit bigger tires on srt struts
Old Apr 29, 2006 | 02:21 AM
spikeymikey87's Avatar
spikeymikey87
Default why can you fit bigger tires on srt struts
what about the srt struts makes it so that you can fit a bigger tire on your car. also is it a direct fit and how well will they hold up with a eibach proline or sportline springs in them on a 04 sxt?
Old Apr 29, 2006 | 02:38 AM
03neonRT's Avatar
03neonRT
Default RE: why can you fit bigger tires on srt struts
The perch on the SRT struts are higher and smaller than on our struts, thus making it able to have wider, taller tires. The SRT struts should hold up much better to prolines or sportlines than our truts, but you will still run into issues over the long term. Unless your getting a really good deal on the SRT struts (which a set of 4 can be had used for $75-$200) then you might as well look into some Tokico HP Blues which will be much better than SRT struts.
Old Apr 30, 2006 | 12:41 AM
spikeymikey87
what size rim and tires can you fit on a tokico hp blue and i can only find them in a 1.4 in drom in the front and in the rear right but not left is that normal?
