Engine light just came on for first time. How do I check the codes for what's wrong?
Old May 2, 2006 | 12:01 PM
mashumk's Avatar
mashumk
Default Engine light just came on for first time. How do I check the codes for what's wrong?
How do I check the codes for what's wrong? It's an 02 model and about 101,000 miles. Thanks.
Old May 2, 2006 | 01:32 PM
gtxpooch's Avatar
gtxpooch
Default RE: Engine light just came on for first time. How do I check the codes for what's wrong?
Take to your local auto parts store, Checker, Autozone, etc. most of them will check the codes for you for free, then you can go from there.
Old May 2, 2006 | 02:59 PM
mashumk's Avatar
mashumk
Thanks. Isn't there also a way to reset the computer to turn the engine light off and see if it comes on again? I remember reading something about disconnecting the negative of the battery for 30 seconds and the engine light will go off upon reconnection.
Old May 2, 2006 | 04:17 PM
mashumk's Avatar
mashumk
solved the problem myself. just a loose gas cap haha
Old May 3, 2006 | 01:26 PM
tooslow's Avatar
tooslow
ok btw here is how too check for engine codes
turn the ignition
on/off/on/off/on and looks at the odemeter it will show the code there and then say done
