cluster w/ tach ?
Old May 11, 2006 | 05:34 PM
moobit's Avatar
moobit
Default cluster w/ tach ?
I have a 00 neon, it originally had the cluster without the tach, but i went out and bought the sxt cluster, the one with the tach. I noticed everything is working normal but im just wondering what the little red circle in the top right corner is meant for??? My old cluter didnt seem to have that little red circle, but this one does, but i dont know what it is for?? thanks. juan.
Old May 11, 2006 | 10:41 PM
03neonRT's Avatar
03neonRT
Default RE: cluster w/ tach ?
ABS perhaps?
Old May 12, 2006 | 12:07 AM
moobit's Avatar
moobit
I dont think so, there is another display on the left side that says ABS. So i doubt its for that. Its just a circle that lights up red sometimes and times when it doesnt, i havent notice when it does or it doesnt, but i just dont know what its for?? thanks.
Old May 12, 2006 | 02:10 AM
03neonRT's Avatar
03neonRT
Well i'm too lazy to walk out to my car and do this myself...so get a flash light and shine it on the cluster, you'll be able to see the outline of the symbol very clearly. Then crack open your owners manual and there will be a key of symbols that will tell you what each one means. Even if your car didnt come with the tach cluster all these should still be in there.
Old May 12, 2006 | 02:24 AM
clean_sx's Avatar
clean_sx
if it is a little red dot that flashes about three times when you start up it is the "security thingy".
Old May 12, 2006 | 04:56 AM
moobit's Avatar
moobit
I guess that "security thingy" would make more sense, but i will try to find out and see if there is anything around to see what it might be. Since i dont have an alarm, i guess it would make sense if it would be on all the time, or off, but theres times where its on and times when its off. My car is all manual too, nothing electric. thanks.
Old May 12, 2006 | 10:45 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
yup, its a security thingy... if you had the optional 'security things' installed, after you hit the lock button the little red light blinks to let you know the car's high-tech alarm system is armed
Old May 13, 2006 | 01:54 AM
moobit's Avatar
moobit
im talking about this little red dot on the top right corner, next to the seat belt display..
[IMG]local://upfiles/28565/7B8C72B976994FDD95A31D40BB25D0DE.jpg[/IMG]
Old May 13, 2006 | 07:19 PM
flamingpinhead
Section Moderator
ORIGINAL: moobit
yup, thats it. if you dont have the security system, it should just come on for a second or two and go off.
Old May 13, 2006 | 08:06 PM
moobit's Avatar
moobit
O, but its usually on all the time, its off when i barely turn it on but then after a while it turns on and just stays on. But atleast i know what it is now, doesnt really matter now though casue i dont have an alarm on my car. But yeayh, thanks anyway.
