Correct PSI?
Old May 13, 2006 | 01:36 PM
AbsoluteZeRo's Avatar
AbsoluteZeRo
Default Correct PSI?
What is the right PSI for my 04 neon SE? It has stock tires\wheels.
Old May 13, 2006 | 05:47 PM
03neonRT's Avatar
03neonRT
Default RE: Correct PSI?
Well my stock PSI is 32...but i have 16's so it might be differnet with yours, but it should be very similar.
Old May 13, 2006 | 06:56 PM
Bassboy's Avatar
Bassboy
Check the tires, it usually says the rated psi on them, most are around 32psi.
Old May 13, 2006 | 07:16 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
look around the doorjam on the drivers door. there is a placard that has the recommended tire pressures for your vehicle. it should be on the door itself or the lower portion of the pillar.
Old May 13, 2006 | 09:46 PM
ewetho's Avatar
ewetho
My 04 Neon SE is 32 PSI Front and 32 PSI Rear and 60 PSI Compact Spare. By Door Jam!
Old May 14, 2006 | 03:08 AM
spikeymikey87's Avatar
spikeymikey87
35 psi is a generic pressure on all passenger vehicles but to make it more comfortable people usually have it at 32-33
