LED Tail Light Wiring Problem
Old May 14, 2006 | 01:53 AM
primusfisherman's Avatar
primusfisherman
Default LED Tail Light Wiring Problem
I am having a problem wiring in my new led tail lights for my 05 sxt. All my fuses are good and the problem is that when my headlights are on and I push on the brake, instead of the leds lighting brighter they shut off completely. The lights didnt come with any instructions and a wiring diagram would be nice. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Old May 14, 2006 | 03:04 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: LED Tail Light Wiring Problem
well theres not really a wiring diagram did you mess with the wires at all you just plug the thing that used to be in a light bulb in the light. check it and make sure no wires are crossed i guess
Old May 14, 2006 | 11:48 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
is it just a 'plug and play'? check to make sure your brake light connection dosent have a short somewhere or is crossing wires. try hooking your origional brakelight and see if it functions correctly to see the problem is with your led lights or with the wiring in your car
