p0133 code
Old May 22, 2006 | 01:03 AM
dave2690's Avatar
dave2690
Default p0133 code
so will a new 02 senser fix the trouble or could it be much more
Old May 22, 2006 | 02:01 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: p0133 code
check connections, then replace O2 sensor, then worry bout more troubles
Old May 23, 2006 | 08:08 AM
RadarLove's Avatar
RadarLove
P0133 is the upstream sensor slow response time. Wiring issues shouldn't cause this. Either the sensor is fouled, out of place, or failing. Replacing the sensor should do the trick. Personally, I'd go with the NTK brand (which is what you'll get at the dealer). I've had nothing but trouble with a Bosch replacement within a few months after getting it... Worth the extra few bucks...
Best of luck!
Old May 25, 2006 | 12:33 AM
dave2690's Avatar
dave2690
thanks for the info this will be a great help.
Old May 25, 2006 | 12:34 AM
dave2690's Avatar
dave2690
thanks for the info
