Magnum Turbo Flange?
Old May 24, 2006 | 02:52 AM
bebi_wilson's Avatar
bebi_wilson
Default Magnum Turbo Flange?
I contacted Hahn Racecraft and was informed that they do not make a turbo kit for the magnum head. I was wondering if there is a workaround so i can use the Hahn Turbo on the magnum head? Or if anybody knows where i can get a chill factory turbo kit?, as they make a Magnum Kit.
Old May 25, 2006 | 10:58 PM
bebi_wilson
Default RE: Magnum Turbo Flange?
bumb
Old May 25, 2006 | 10:59 PM
bebi_wilson
haha, I mean bumP
Old May 27, 2006 | 04:12 AM
tooslow's Avatar
tooslow
do you want the whole mani or just the flange
whole mani
http://thestreetsource.net/
Old May 28, 2006 | 04:48 PM
RadarLove's Avatar
RadarLove
Or jsut slot the bolt holes on the Hahn supplied manifold to raise it up, and make sure the ports are big enough to not be a restriction.
Very odd that they don't make a Magnum-friendly setup...
Best of luck!
Old May 30, 2006 | 04:06 PM
tooslow's Avatar
tooslow
the bolts should line up but if it is non mag the holes are gonna be smaller you can probally just port the manifold if there is enough metal so it lines up it can be little bit bigger but not smaller
Old Jun 3, 2006 | 06:38 AM
RadarLove's Avatar
RadarLove
The Magnum exhaust ports sit up higher. If you use the non-magnum bolt holes, the exhaust ports on the head will not line up with the manifold ports.
