engine swap?
I have an 05 neon se and was wondering if it is possible to swap in an srt engine and computer and mate it to my auto tranny ( my wife had a hip replacement and cant bend her leg enought to drive a stick). Also concidering a possible swap to a 2000-2002 engine and computer. For that matter would it be possible to just swap the computer from an 02 to my car seeing as i believe they are the same engines .I know the computer in this car won't let us really upgrade our cars so i was wondering if anybody really sees any performance gains with all these parts they put on there 03-05's. I don't really need to go any faster than the 175kph i have gotten it but i want better off the line performace rather than top speed. Any info on any of these questions would be great thanks.
RE: engine swap?
Well first off, you cannot simply swap in a 01-02 computer into an 03-05 because the plugs and sensors are very very different. As far as the SRT swap, you can use the automatic tranny out of a PT turbo, rather than the 5-speed tranny. For the SRT sweep you'll need the following parts:
Engine and Tranny Complete Engine Wiring Harness Complete Engine Bay Wiring Harness Power Steering Pump, lines, and cooler Intercooler Piping Intercooler Radiator Hoses Motor Mounts (the holes are larger on the the upper and lower mounts for larger bolts) SRT PCM (wont' need the bracket with 03+) Axles (and half shaft if it isn't on the engine) Coolant Bottle Fuel Line from tank to engine bay Fuel Pump Flex Fuel line from solid fuel line to fuel rail Short evap hose that comes from the purge valve All vacuum lines and the 3 selonids o2 Sensors Turbo Housing + o2 Housing Lower Control Arms You coul swap into a 01-02 R/T or reglar engine and computer, but for a few extra you might as well go for the SRT swap...hope that answered your questions somewhat. |
