Turbo Project...*Updated*
Old Jun 24, 2006 | 01:30 AM
03neonRT's Avatar
03neonRT
Default Turbo Project...*Updated*
The day i have long awaited for has finally arrived...i have purchased my SRT Turbo, manifold, BOV, 02 housing, SRT stage 0 injectors, Walboro 255 fuel pump, and about to order my gauges, pods, and a rear section off an SRT-4. Next I'll be getting a stock SRT IC, hot and cold pipes, Melling M190 oil pump, all the coolant, oil, and vacuum lines, the RRFPR, and the SOHC Manfold Plate. (and a few other things)
Wish me luck people!
Old Jun 24, 2006 | 03:32 AM
Acrfanatic's Avatar
Acrfanatic
Default RE: Its Finally Happening!
Thats awesome man...let me know how it is when you have installed it. That is going to be so freakin sweet. Your so lucky!!
Old Jun 24, 2006 | 04:30 PM
03neonRT's Avatar
03neonRT
Thanks man, the only problem is this is gonna cost me about $1,500...then i have to send it away for tuning (and i dont know how much that costs yet), and of course a dyno to see how much its making. Hopefully my little project will be done by the second week of July...but we'll see.
Old Jun 24, 2006 | 05:59 PM
tooslow's Avatar
tooslow
ok here is some tips
you have too relocate the stock ecu too get the intercooler in and also have too cut into the car too get it in there nothing major but have a grinder handy
too get the hot side pipe in you need too move the power steering cooler. the hot side pipe is not impissible too get in but it is pain too get on there
also atach all the lines except the the oil feed before putting on the turbo and do the manifold bfore you do the turbo
goodluck and just think before putting something on because there is very little space and it will safe tons of time
Old Jun 25, 2006 | 12:51 AM
03neonRT's Avatar
03neonRT
Yeah i knew about all those little "problems" lol...you have no ideea how much research i did on this before i even thought about. I'm just hoping this goes somewhat smoothly and i dont screw something up!
Old Jun 25, 2006 | 01:33 PM
tooslow's Avatar
tooslow
Don't worry if you did your homework you should be fine
goodluck again
Old Jun 26, 2006 | 05:26 PM
03neonRT's Avatar
03neonRT
IC bought...does anyone know a good place to buy the IC hot/cold side piping?
Old Jun 26, 2006 | 05:31 PM
tooslow's Avatar
tooslow
you don't really need the cold side pipe you just need 2 90deg elbows and about 12inches of sraight tubing the srt cold side pipe does not fit as is I had too add a 90deg elbow too make it work
the hot side piping might be hard too get I would go too srt boards you might get lucky
Old Jun 27, 2006 | 02:14 AM
hokiefan104's Avatar
hokiefan104
dizzam someone came across some cash money. good luck with the installs.
Old Jun 27, 2006 | 03:39 AM
03neonRT's Avatar
03neonRT
ORIGINAL: hokiefan104
Yeah you could say that...now i just need to find some IC piping!!
