Where is the fuse for the rear cargo (trunk) light located?
Old Jul 3, 2006 | 10:54 PM
stargirl's Avatar
stargirl
Default Where is the fuse for the rear cargo (trunk) light located?
My trunk light's out. It's not the bulb, because I've tried to put a new one in. It must be the fuse, but I can't find where the fuse is for the trunk/rear cargo lid. >.< Any suggestions? Please help.
Edit: I have a 2000 Dodge Neon.
Old Jul 7, 2006 | 02:41 AM
kishore's Avatar
kishore
Default RE: Where is the fuse for the rear cargo (trunk) light located?
Fuse is FS13 rating 15 Amps. If you have a underhood lamp or a glove box lamp its the same fuse also this fuse is for the Dome light.
If your dome light comes on then the fuse is good.
If you see the cargo lamp holder the Pink wire is hot at Tan/Black whire goes to ground via the decklid release switch.
Kishore
