quick question
Old Jul 4, 2006 | 03:56 AM
infectioussxt's Avatar
infectioussxt
Default quick question
Ok I have a 05 Neon SXT and am thinkin of puttin electronics under the rear bench seat, but am unsure of whats there. Anybody know? I'm lookin to put a box with dimensions of 15.8 x 3.8 x 12.8 WxHxD (in inches), but before I put time into actually tearin it up and messin with it wanted to know if anybody could give me an easier answer :P
I would like to put an amp under there, with wires in/out and not completely sealed off either (was planning on cutting a hole under the bench seats, use a rubber lineing, and make a door that i could lock).
Old Jul 4, 2006 | 11:22 PM
hlfbck20's Avatar
hlfbck20
Default RE: quick question
it should be the same as my car.. and you can pick it up by just pulling upwards on it... and btw there is really nothing under there... but i dont know if you would really want to put an amp under the seat... if your rear seats fold down, would you consider mounting the amp on the back of the seat???
if your talking actually the underside of the car.. i believe the exaust pipe runs down the driverside of the car and i think the gas tank is around there somewhere too...
Old Jul 5, 2006 | 04:10 AM
infectioussxt
just on the inside of the car (on the direct opposite side of the top of the seat)
Old Jul 6, 2006 | 04:22 AM
hlfbck20's Avatar
hlfbck20
yeah there is nothing underneath there.. just the bottom of the car...and the bolts that hold the seat belts down.. and if ur tryin to take them out i believe you need a t060 torx bit.. just an fyi if you wanted to remove them...
