wheel bolt pattern, Wheel adapter
Old Jul 26, 2006 | 01:53 AM
NEon4shoo's Avatar
NEon4shoo
Default wheel bolt pattern, Wheel adapter
My friend has a 02 neon and i know hes 5 bolt but is he 5x100???? Also is there a place that sells wheel adapters to turn it into a 5x112?? I have these tires that are 18in with 35 offset once we turn it into the 5x112 will they fit?? Thanks 4 all your help
Old Jul 26, 2006 | 02:10 AM
03neonRT's Avatar
03neonRT
Default RE: wheel bolt pattern, Wheel adapter
Yes the 00-05 Neon's all had the saem 5x100 bolt pattern...as for the wheel adaptor, i dont believe they make any, because that would sound pretty unsafe trying to "change" your bolt pattern...
Old Jul 26, 2006 | 02:02 PM
Dagget427's Avatar
Dagget427
You can get wheel adapters and they are safe, just not cheap ( $75 - $100 a pair ). Check with tirerack.com discounttirediect.com or even e-bay
Old Jul 26, 2006 | 02:33 PM
LowSlowNeon's Avatar
LowSlowNeon
Wheel adapters? They make wheel spacers......but I haven't heard of wheel adapters.
Old Jul 26, 2006 | 04:39 PM
Dagget427's Avatar
Dagget427
Check out item number 280009076234 on E-bay. Not the right size for NEon2shoo, but that's what they look like.
