How much to change the Cat converter?
Old Jul 28, 2006 | 09:04 PM
redskinz56's Avatar
redskinz56
Default How much to change the Cat converter?
how much would be a fair price to change a Cat converter? for a dodge neon. I think its fried cuz i got black smoke coming out the muffler.
Old Jul 29, 2006 | 09:49 PM
03neonRT's Avatar
03neonRT
Default RE: How much to change the Cat converter?
Well a high flow cat (or an OEM spec cat) will cost around $100-$120, then probably another $100 for labor costs depending on the shop you take it too...
Old Aug 1, 2006 | 04:50 PM
redskinz56's Avatar
redskinz56
oh ok not too expensive then.... n is there a certain time period u should change this?
Old Aug 1, 2006 | 04:51 PM
redskinz56's Avatar
redskinz56
is there a particular site i should get the cat and what exactly does the cat do for the car?
Old Aug 1, 2006 | 07:03 PM
03neonRT's Avatar
03neonRT
I would go to modernperformance.com for a high flow cat, but if you just want an OEM replacement just do a search for them...usually you only change the cat when it goes out, and on most cars it should last beyond 100,000 miles, but sometimes they dont.
Basically all the cat does is reduce emmissions from your vehicle...
Old Aug 1, 2006 | 07:36 PM
redskinz56's Avatar
redskinz56
sounds right because my car is at 92K right now. my check engine light is directing me to the cat and coolant
