does anyone run megasquirt
right now it alot of work too hook up ms on 03+ but pretty soon it will be easier and cheaper they were testing the 03+ code last time checked
but here is what my setup cosists of basically
http://megasquirt.sourceforge.net/ex...atyouneed.html
you alsoneed a gm colant temp senser and air intake temp senser
this is what you need if you have pre ngc neon and if they get the ngc crank trigger decoded it will be about the same too setup 03+
http://megasquirt.sourceforge.net/extra/setup-neon.html
oh yeah I have ms1 with the v3 board with edis mod and I am running firmware q29
I also have relay board but it just makes it easier too wire but aint really needed
