Flowmaster
Old Aug 4, 2006 | 02:32 AM
ab_cartman's Avatar
ab_cartman
Default Flowmaster
I really want to upgrade my exhaust but i really don't have the money right now to get anything really good, so i was looking around and a found a flowmaster 2 chamber muffler that says it will fit an 04 neon should i get it just to hold me over until i can afford a better system it is only like 60 dollars?
Old Aug 4, 2006 | 03:06 AM
srt boy's Avatar
srt boy
Default RE: Flowmaster
Hey for $60 dollars how can you go wrong!And later on if you get a obx header and a high flow cat you won't even need a new exhaust system.
Old Aug 4, 2006 | 04:07 AM
camlen1098's Avatar
camlen1098
I totally agree....go with it for now....I got an OBX Muffler for like $150 (installed) and I just recently got the OBX headers and Downpipe for $124 (uninstalled) so for only around 300 bucks you really can have a good exhaust.....oh I almost forgot I got 3 inch pipeing all the way to the muffler too, that cost me another $50 at the local muffler shop....so I guess that brings it all to about $324....which aint too bad at all....
Old Aug 6, 2006 | 11:10 PM
hokiefan104's Avatar
hokiefan104
where did you get OBX headers for that cheap?
Old Aug 7, 2006 | 03:17 PM
03neonRT's Avatar
03neonRT
ORIGINAL: camlen1098
oh I almost forgot I got 3 inch pipeing all the way to the muffler too....
Just out of curiosity, but why in gods name would you run 3" piping on your N/A Neon??
Old Aug 7, 2006 | 04:56 PM
fraggle_a's Avatar
fraggle_a
Because he can.
Wouldnt a bigger diamiter mean a reduced velocity at the muffler end?.
I can see that it would cause issues with the smooth flow of exhaust gasses though.
Im just going to upgrade mine to 2 1/4 to match my muffler size.
I would imagine the most efficient exhaust would be the same size as the exhaust from the engine?
(so, 4 exhausts at.. Im guessing 3/4 out of the engine block? would be 3". But since they arnt all blowing at the same time you can take 3/4 off that?. I have no idea, just ignore me......)
Old Aug 7, 2006 | 09:50 PM
timplett's Avatar
timplett
If you figure that the exhaust ports are 3/4" in diamater that equals 1.7" sq area if you are taking a flat cross section of the exhaust. The area of a cross section of 3" pipe is 7.065" sq. Assuming the ports are 3/4", the closest match in diameter is 1.5" piping. Now this is figured out assuming the exhaust ports are round and 3/4" in diameter (which I don't think would be correct) and that the perfect exhaust is identically matched to the exhaust port total area. Just a little math based off what other people are saying.
