overheating?
Old Aug 5, 2006 | 08:40 PM
spoiledbrat's Avatar
spoiledbrat
Default overheating?
i have an 04 neon, i just noticed it getting hot with a/c on, the radiator fans are not working, how do i tell if its a sensor in the a/c
or if its the relays
taking it to dealer on monday but if i can save money id appreciate the help
Old Aug 6, 2006 | 03:40 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: overheating?
How do you know the radiator fans aren't working? I can't tell if they're on usually with the A/C on unless I'm out of the car. Is it pegging out or is it just rising a little bit?
Old Aug 6, 2006 | 03:35 PM
timplett's Avatar
timplett
I don't think I've ever seen the temperature meter on my Neon go over a quarter of the way up, even with heavy driving. I doubt, however, that you have a problem unless it goes over halfway up.
Old Aug 6, 2006 | 03:42 PM
spoiledbrat
its just about redline and you smell the coolant, im out of the car with it running and the a/c on
dealer said that the fans always run with a/c on
Old Aug 6, 2006 | 04:48 PM
ewetho's Avatar
ewetho
You need to test that coolant system for holding pressure, that inclused the cap. If system is tight, it is either a pump or thermostat most likely. Check the fins on your radiator for dirt build up. Escpecially between the AC condensor and raditator..
Old Aug 6, 2006 | 06:45 PM
hlfbck20's Avatar
hlfbck20
did you ever mix the coolants?? you know dexcool with the regular yellow ****?? bc that basically causes it to sludge up and mess everything up... might want to look into that one..
