Gauges and lighting...
Old Aug 10, 2006 | 05:57 AM
camlen1098's Avatar
camlen1098
Default Gauges and lighting...
I know this is kinda riddiculous, but do the 2 1/16" gauges that Mopar makes work along with your headlights or do you have to wire them in to do that? I have seen pics of the gauges in LowSlowNeon's car....and I was just wondering if it took extensive wireing to have them glow blue.....or was it just the basic wireing that is reccomended when you buy the gauges...Thanks for any feedback...
Old Aug 10, 2006 | 10:36 AM
03neonRT's Avatar
03neonRT
Default RE: Gauges and lighting...
You just tap the gauges into a power source, pretty basic install if you know anything about wiring.
Old Aug 21, 2006 | 02:20 AM
NorthernR/T's Avatar
NorthernR/T
yes pretty straight forward, a person can tap into the dimmer switch to adjust the brightness of the lights in ur gauges as well, have to pull the wiring schematics but i think its the brown wire with yellow tracer. wire in a relay if running more then one gauge, or at least minimum a fuse
