mopar a/f gauge
Old Aug 15, 2006 | 03:15 AM
CA180's Avatar
CA180
Default RE: mopar a/f gauge
wideband runs off of a o2 sensor that has a built in heater so you get an accurate reading all the time.
Old Aug 15, 2006 | 03:24 AM
spikeymikey87's Avatar
spikeymikey87
well i just found out that a wideband is about twice the price of a narrowband so it must be a big difference
CA180's Avatar
CA180
tru dat
Old Aug 15, 2006 | 05:32 AM
03neonRT's Avatar
03neonRT
Yes, a wideband is much better than a narrow band A/F gauge...it will give your exact A/F readings while a narroband simply says whether your at Rich or Lean...you wont need one unless you go turbo, and if you do narrowband there is no point in spending $100+ on a Mopar/Autometer gauge when you can find them cheaper. With that said, spend the $280 on the AEM auge and do it right the first time...it will cost more but save in the long run (on a F/I application)!
Old Aug 16, 2006 | 01:34 AM
spikeymikey87
how does te sensor for it work. does it replace the upstream o2 sensor and then is spliced into it or does a new bung need to be drilled and welded in?
Old Aug 16, 2006 | 02:53 PM
03neonRT's Avatar
03neonRT
You need a new bung for the wideband 02 sensor.
Old Aug 16, 2006 | 03:13 PM
spikeymikey87
ok thanks
Old Aug 17, 2006 | 02:36 PM
nicks2kes's Avatar
nicks2kes
yea the wideband will give u an actuall number for ur afr's as opossed to a narrowband will just give u an idea of how rich/lean ur running. go with the wideband hands down, narrowbands are a waste of money
Old Aug 17, 2006 | 05:51 PM
BlueOnBlack's Avatar
BlueOnBlack
me and one of my friends hooked up one in his 94 vw golf and it was stupid on his car cause he had a 4" fart can on the back and it just bounced around the whole time it worked but it was weird inless you really need it i wouldn't even bother with it
Old Aug 17, 2006 | 06:15 PM
spikeymikey87
well i plan on going megasqurt then turbo so i kinda need it
