sway bar end link adapters?
Old Aug 15, 2006 | 02:24 PM
CA180's Avatar
CA180
Default sway bar end link adapters?
I was reading in an earlier post somewhere that eibach used mopar adapters to put the sway bar on the non-r/t neons... does anyone have this part number or know where i could pick some up? My guys here in parts cant seem to find any info on it, and i'm seriously tired of understeer on my car! If anybody has some info, let me know... \\thanks in advance, stephen
Old Aug 15, 2006 | 04:06 PM
CA180's Avatar
CA180
Default RE: sway bar end link adapters?
Nevermind,,, called eibach myself and got the mopar parts numbers...
For future reference they are...
DGE4626765
and
DGE4626764
they didnt tell me which one was right or left, but i'm sure the parts catalog at the dealership will have pics.
*edit* My parts guys told me that the odd numbers on the end are usually the left side.
Old Aug 15, 2006 | 06:13 PM
LowSlowNeon's Avatar
LowSlowNeon
I was just about to tell you to call eibach. I actually broke one of them...well it more or less rusted and broke. I believe in dodges/mopar system they drop off the dge. I had to reorder one. It was about 12 dollars I think.....somewhere around that price range. And they work beautifully other then one of mine broke from rusting....
Old Aug 15, 2006 | 06:58 PM
CA180's Avatar
CA180
yeah, you wouldnt happen to have a spare rear bar would ya?
I get em here a dodge at 2 for $19.96 right and left, just need the bar! LOL
Old Aug 15, 2006 | 08:43 PM
ewetho's Avatar
ewetho
These adapters are you looking for the Perches that the endlinks attach too or just the endlinks themselves. The only adapters I have seen are the 1st gen which means ou now need special endlinks. Most 2gn sway bars are using verticle attaching endlinks. Just a bolt with bushings and sleeves on it. The adapters from a 1st gen are actually verticle requiring a ball socket to make the 90 degree turn to the hole in the verticle mount. If you got a hotchkis bar you would then need 2 90 degree ball sockets as there bar is 90 off normal Neon stuff. If you have a standard bar or Progress bar then you could get hotchkiss endlinks and use them upside down. Make sure what you are getting. The best way around this is to simply replace the rear struts. This would give you a stock style mounting point and then you could get what ever floats your boat.
