2000 Neon will not start
Old Aug 19, 2006 | 07:38 PM
DrBuffer's Avatar
DrBuffer
Default 2000 Neon will not start
Replaced head and CMP after head gasket blew. No voltage to coil. Switched ASD relay, still no spark. No codes showing in computer. Is there anything besides the PCM that would cause this problem? Is there any way to check the PCM?
Old Aug 26, 2006 | 05:24 AM
EDK's Avatar
EDK
Default RE: 2000 Neon will not start
is the timing right if not your pcm will trip the relay before it even trys to spark and you might cheak your asd fuse
