Lambo Conversion Help Please
Old Aug 24, 2006 | 01:13 PM
Streetuner's Avatar
Streetuner
Default Lambo Conversion Help Please
I have a 2002 dodge neon with a full body kit and a spoiler. The next step in my process is to do a lambo (or vertical) door conversion. I have done research on several different kits however; everyone says that they have the best kit. I want quality but I would still like to have money to do other things. Could someone that has done a conversion already (and had the doors for over a year, with no problems) or someone very knowledgeable in this area help me out.
Old Aug 24, 2006 | 03:31 PM
timplett's Avatar
timplett
Default RE: Lambo Conversion Help Please
I have no first-hand experience with lambo doors, but I think you really need to ask yourself if it's worth it, because most of the time, it makes it much harder to get in the car, they're just a pain in the behind. The only advice I can really give, is that I have seen that Autoloc advertises 135 degree opening lambo doors, which means it would actually open far enough to be useful. I would look into whether or not they have a 135 degree kit for the Neon.
Old Aug 24, 2006 | 04:19 PM
hlfbck20's Avatar
hlfbck20
things can always be fabricated to make a lambo door kit work if there isnt one that opens enough for the neon...much more time consuming but it can be done... and do you really want to set yourself back that much.. bc arent lambo kits expensive...upgrade the engine or something... or are you going for the all show no go look??
Old Aug 24, 2006 | 04:38 PM
timplett's Avatar
timplett
I did a little bit of checking into the Autoloc 130 degree (not 135, sorry) door kits. They are universal, so they will fit your Neon. The automatic kit cost $2100 though, and the manual was somethig like $1700 I think. That goes a long ways towards a turbo kit, not worth it.
