not starting right
Old Aug 27, 2006 | 03:02 AM
spikeymikey87's Avatar
spikeymikey87
Default not starting right
hey guys lately my car hasnt been starting as quick as it usually does i thought it was just the spark plugs but thore are changed and it makes no difference. the starter cranks the engine but it dont start for a little bit and its starting to scare me im thinking of maybe the injectors are a little clogged so it cant get enough fuel so what kind of fuel additive should i get for that or should i do something else. also if you have any other suggestions of what it might be please tell.
Old Aug 27, 2006 | 03:06 AM
03neonRT's Avatar
03neonRT
Default RE: not starting right
Sounds like you need a new battery...
Old Aug 27, 2006 | 03:41 AM
fraggle_a's Avatar
fraggle_a
Pull a plug and look for damage, or deposits.
Run a cleaner through the tank. Some folkes like the Techron, most of them are pretty much the same if you look close enough.
Check your oil, see if it needs some attention.
Check battery,
Check the starter....
