weird situation
Old Aug 27, 2006 | 09:42 PM
redskinz56's Avatar
redskinz56
Default weird situation
this is kind of weird atleast for me cuz its never happend but if u think otherwise let me know.
what happen was that i had my check engine light giving me codes of P118(coolant sensor) & P420 (catalyic converter)
all i did was change the coolant sensor first since it was only about $30. a very simple task if you got the right tools and ive never even worked on a car before until someone told me its very simple to do.
once i turned the car back on after changing the sensor.... the check engine light was no longer on. NOT EVEN FOR THE CATALYIC CONVERTER.
hmmm..
Old Aug 28, 2006 | 01:21 AM
03neonRT's Avatar
03neonRT
Default RE: weird situation
Give it a few days, it might just be the fact that the PCM cleared all codes when it "realized" the coolant issue was no more, and it simply hasnt re-detected (is that even a word?) the cat problem yet...if it doesnt come on after a few hundred miles then you may not have a problem...sometimes the PCM gets things wrong, sensors interact with other sensors for no reason, things affect unrelated things, it happens all the time when computers are involved. Its not a 100% accurate monitoring system by any means...
Old Aug 28, 2006 | 02:14 AM
timplett's Avatar
timplett
Yea sometimes it just gets a little screwy. My check engine light was on for a few days (yes I checked the gas cap seeing as apparently that's why it's on half the time) and then after a few days it shut off and hasn't come back.
Old Aug 28, 2006 | 03:30 PM
fraggle_a's Avatar
fraggle_a
when I had my incomming air temp sencor unhooked I had the engine and battery lights come on.
I never did read the error code, i knew it was something to do with that anyway.
I had a nice error on the saturn though, telling me the fuel mix was too rich, when the sencor in the exhaust had burnt out.
