FUel filter 2001 is it the screen..
Old Aug 28, 2006 | 12:51 AM
bigbaDEREK's Avatar
bigbaDEREK
Default FUel filter 2001 is it the screen..
is it the screen or the filter in a 2001 this is the cut off year between them and i was wondering if this has it cause my car is a dog in the lower rpm's ...like really bad replaced plugs, cold air, fuel system clean oil changed.....next ?
can i check my fuel presure with a simple tire guage? PLease help and thanks
Old Aug 28, 2006 | 01:17 AM
03neonRT's Avatar
03neonRT
Default RE: FUel filter 2001 is it the screen..
The Neon has an in-tank fuel filter, and if there was a problem with your fuel pressure you would be throwing codes like no other...and no, as far as i know you cant check fuel pressure with a tire gauge, you need a pressure regulator attachment.
Old Aug 29, 2006 | 10:03 AM
bigbaDEREK's Avatar
bigbaDEREK
thanks sounds good. I just know that was the cut off year of the fuel filter and i know it would be in the tank but is it the built in to the pump screen or the actual filter...i hear some do and some dont
