Adding an amp and subs
Old Sep 6, 2006 | 04:00 PM
Dagget427's Avatar
Dagget427
Default Adding an amp and subs
I have a 05 SXT and want to add an amp and subs. Does the factory stereo have pre outs for this, or do I have to get an amp that has speaker level inputs and splice into the factory wiring?
Old Sep 6, 2006 | 05:22 PM
Pharmboy's Avatar
Pharmboy
Default RE: Adding an amp and subs
It won't have pre outs, and the easiest way to wire it is to the rear speakers with a crossover.
Old Sep 6, 2006 | 06:28 PM
Tenth_element's Avatar
Tenth_element
my amp is hooked up through the rear speakers, cept no crossover ( I took it to my friend who owns a audio shop) and it works just fine
BTW its a acoustic gothic series amp 1600W 2-channel
Old Sep 6, 2006 | 06:47 PM
Pharmboy's Avatar
Pharmboy
never heard of that one, but many amps have built in crossovers. In that case it's fine.
Old Sep 6, 2006 | 11:38 PM
timplett's Avatar
timplett
If it has high level inputs, and has a LPF setting, which most good brand name amps do, you have nothing to worry about. Lots of amps need a connector for their high level imputs, so you might have to find the proper connector. Even if you make the install yourself, I would seriously advise talking to the guy at your local car audio shop about it. They will give you helpful tips about installation and setup for free (unless they're jerks, which is always possible). I installed mine all myself but the guy at the car audio shop near me gave me a couple setup hints and after I follow his hints I got twice the volume out of my sub and speakers.
Old Sep 9, 2006 | 04:45 AM
srt boy's Avatar
srt boy
JUST GO BUY A HIGH LOW BYPASS.THERE FAIRLY CHEAP $20-$30.They hook up to the stock deck and supply the rca lines you need to run the amp.They also have an adjustable output level so you can match it to the power of the amp.I have one in my car made by stinger with gold binding posts.Works pretty good.I noticed it also cleared up some of the high level distortion in my other speakers.But to get that you have to make sure you hook up the optional ground that it has.
